Home Forums Classifieds Classifieds – Parts CR125/Rotax /ICC engine parts new/used
    • #9138
      Mike Beeny
      1-Mychron 3 Gold Ebox and gauge with Mychron steering wheel. (USED)
      Has not been used for several years but was in good working condition when removed from kart.  Steering wheel is a little rough.  Download cable included.
      $250.00
      1- Bullseye model B2 laser alignment system.  Have had for many years but only used a few times.  The Sniper B2 is the taller version of the original Sniper and can be mounted on 40mm hubs or 17mm spindles .  With an adapter it can also be mounted on 25mm spindles but i do not have that part.
      $350.00
      1-Racejet weather pod (new) with race Jet software for Windows and palm version 1.10
      Includes MaxJet FR125 Max version 1.3, Modem cable for downloads, Instructions.
      Serial# 04RJ-DB9-R.D-240470
      $150.00
      27- RS125 piston rings (New, in OEM bag) P/N 13121-NX5-701
      $15.00 each
      1-Race Jet weather pod (used a few times) with race Jet software for Windows and Palm version 2.60
      Includes Maxjet FR125-Jr-MiniMax version 1.61a,modem cable for downloads, instructions
      Serial# 05RJ-DB9-REV.F251167
      $100.00
      1-ICC jet kit
       Mains
      118,120,122,124,125,126,127,128,129,130,132,140,142,145,148,158,160,165,168,175
      Emulsion tubes DP 260,DP 267, DP268, DQ 261, DQ 262, DQ 265, DQ 266
      Inner pilots B45, B50, B55
      #40 slide
      Needles K21,K22,U2,U7
      $65.00
      1-Horstman 3rd bearing support (style B) New in box.
      Fits Kt-100s and DAP T-50.
      $40.00
      1- Horstman 3rd bearing support (style C) New in box.
      Fits TKM piston port and Reed, Yamaha Kt-100
      $40.00
      1- Sniper castor pill set (new)
      Left and right side, top and bottom pills
      $75.00
      1-RLV R2 exhaust pipe
      Stinger has been straightened out to keep silencer from burning rear bumper.  This mod did not seem to hurt or help performance.  There is 1 small spot weld to cover a pin hole.
      $90.00
      Stock with no welds
      $110.00
      1-RLV C2 exhaust pipe
      Some welding work done on the header tube around the spring hooks.
      $100.00
      1-BRLV C5 exhaust pipe
      stock with no welds
      $150.00
      1-12″ adjustable/tunable M4 silencer (black type)
      Used for 1 track session.  All tuning spacers included.  1″ ID inlet.
      $125.00
      1-12″ standard M4 silencer (silver type)
      This is an early silencer from around 2004 and has a good amount of use.
      $20.00
      1- 5132 R Elto ICC silencer (new)
      $100.00
      1-PVL ICC ignition coil p/n 105 458 (new)
      $50.00
      1-PVL ICC ignition stator/flywheel (new)
      $175.00
      2006 Maxter ICC counter gears
      2-16t,
      1-17t
      1-18t
      $5.00 each
      Buyer pays shipping.  Pictures available.
      Contact:
      mikebeeny138@gmail.com
