Home Forums Shifter Karts CR125 reeds
Viewing 4 reply threads
    • #36710
      jim lewis
      What are the symptoms of bad reeds on a cr125?  Engine does not want to rev when I go to throttle coming off turns.
      Tried multiple jets – richer – leaner no change.
      Jim
    • #36721
      Richard Kirlin
      Chipped/Crack reeds won’t rev high, will just run rich and limits your rpm.
    • #36723
      jim lewis
      Thanks Richard.
    • #36738
      FREDDY SANDOVAL
      Will also run poorly and backfire at times
      You may also wanna check your fuel lines for cracks/leaks, especially the one for fuel pick up inside the tank, could be slightly cracked/cut and may suck air in the corners.
    • #36741
      jim lewis
      Thanks for the response Freddy. I will check the lines to make sure there are no cracks.
