Home Forums Shifter Karts CR 125 Case Mismatch
    • #45887
      Zach Witzgall
      Hey guys,
      I picked up a 96 CR125 locally from a kid, and needless to say its been through the ringer at least a couple of times. I don’t plan on running  in a class, but more battling it out with a bunch of other local guys, so I’m trying to squeeze more power out of this thing. I’m going to send my cases and cylinder out for porting, but while I was cleaning the cases up, I noticed that the halves are drastically different. One is a pretty standard investment cast piece and the other is sand cast with some coating inside the gear box and a machined crank case surface. The sand cast half is noticeably rougher and seems to have thicker walls.
      My question is; Are two different halves going to be a problem? I can post up pictures if you guys need me to.
      Thanks!
      Zach
