Home Forums General Karting Discussion Chassis/Frame protectors?
This topic contains 6 replies, has 5 voices, and was last updated by  Curtis Cooksey 5 years, 6 months ago.
  • #24874
    Andrew Pachon
    I’ve got a CRG Shifter Kart and I am looking to put some chassis protectors on my kart and I am looking for some advice.
    What all do you guys run and can you share some photos of your set-up?
    Thanks in advance,
    ~A
  • #24879
    Anonymous
    Best advice: Keep it on the track.
    I run some aluminum axle collars snugged up on the frame and lock-tited. You may have to notch the floor plan if you want to put them in the waist of the kart, but they are a heck of a lot cheaper than the frame protector kits you can buy. If they start to wear down too far, throw them away and get some new ones.
  • #24909
    Jason Bane
    I purchased the Tony Kart kerb riders and fit them to my CRG. Just had a drill a couple new holes on the plastic protector to match the holes in my floor pan. The overall shape does not match my Road Rebel frame perfectly, but it’s not bad.  A friend recently installed the Kartlift frame protectors on his new DR kart, they look great.
  • #24913
    Andrew Pachon
    Thanks for the responses gents – much appreciated.
    ~A
  • #24914
    Andrew Pachon
    Derek, can you post a photo of your axle collar set-up?
    ~A
    Best advice: Keep it on the track. I run some aluminum axle collars snugged up on the frame and lock-tited. You may have to notch the floor plan if you want to put them in the waist of the kart, but they are a heck of a lot cheaper than the frame protector kits you can buy. If they start to wear down too far, throw them away and get some new ones.
  • #24919
    Jon Romenesko
    I have some stainless steel  skid plates from PKT…so far so good!
    Always Use (chassis) Protection
    GP10/CR125
    http://theslipangle.com/
  • #24926
    Curtis Cooksey
    Here is a chassis skidplate kit we sell: http://www.accelerationkarting.com/chassisskidplatekit.aspx
    Here is another chassis skidplate kite we sell:http://www.accelerationkarting.com/chassisskidplatekit-1.aspx
    We sell quite a few of these and use them ourselves.
