Home Forums Chassis & Handling Carbon fiber chassis
Viewing 7 reply threads
    • #39281
      Diego Zometa
      Hello guys, Im kinda new to karting. looking around online and reading about karts, I found info about carbon fiber body, but no info on carbon fiber chassis/frames.
      Why is it that they dont make carbon fiber chassis? Carbon fiber is very strong and lighter than metal.
      I know the question to some of you might sound stupid, but again! Im new to this and I couldnt find any info online about it.
      Thanks!
      Im second!
    • #39282
      Gary Osterholt
      Not allowed by the rules.
      Gary Osterholt
      GO Designs, LLC
      http://www.godesigns.us
    • #39285
      Charles Skowron
      Not to mention a steel tubeframe is about the simplest chassis you could make, and the current karts in that form are still way more expensive than they should be. The price of a carbon chassis would be obscene.
      Plus, the strength and stiffness that CFRP can obtain, might not exactly be beneficial to a kart chassis. The peculiar nature of how a modern kart chassis works means that it needs to flex in order to perform properly. Think more in line of  a carbon fiber suspension, rather than an ultra-stiff carbon tub chassis.
      I think I recall someone making a carbon chassis as an experiment nevertheless. Not good for karting anyway to put that idea into production.
    • #39286
      Charles Kaneb
      The CIK doesn’t want the ground-effect aero genie out of the bottle in karting. If I were to build a carbon kart frame, it would have a nice big tunnel down the middle and a pair of replaceable wooden rub strips to seal it.
    • #39287
      Charles Kaneb
      Chuck,
      Is steel cheaper than carbon fiber?
      Design a tension member, 3 ft long, to support 5,000 lbs.
      Go to CarbonFiberTubeShop and price out the carbon fiber tube you’d need.
      Go to AircraftSpruce and price out the steel tube you’d need.
      You’ll be surprised.
    • #39290
      Charles Kaneb
      (Both materials come out to around $1/ton/foot in tension!)
    • #39299
      Karts frames need to flex to work. Steel flexes, carbon doesn’t. Not to mention the cost involved. Not to mention it’s against all governing body rules.
      In a crash, instead of ending up with this:
      You would end up with this:
    • #39312
      Diego Zometa
      Thanks guys!
      Im second!
