my son is getting so big so quick, and not being 13 yet, I thought I’d try and finish one of my abandoned projects and build him an S5 shifter kart…working with a 2010 OTK krypton chassis, 32mm…I’ve gotten some very solid advice from a fellow ekn’er, however I failed to mention to him that we’d be using a 32mm chassis, not a 30mm..and of course being 12 he’s tall and skinny, maybe right at 100lbs….So far the build is going well, it’s time for a seat and final tuning…I’m concerned about the balance from right to left with such a heavy powerplant mounted on the right of the driver. My thought was to set it up as follows — no front bar, neutral camber and castor (as out of the box), axle in lowest position, place the seat where otk says to, set the rear width at 55″, no seat struts to start with, run 130/210s with YLBs….any and all advice is much appreciated here….curious how much importance S5 tuners put on scaling — side to side and front to back — and if so, what is ideal scaling…again, all advice and help is much appreciated
