Professionally rebuilt karts with strong low-hours engines. $1900 each, please contact Eric 626.232.9477 or e-mail eric@seventh-gear.com . Additional photos available. Located in southern California, can ship anywhere in the lower 48 states for $225 – $275.
Sodi Kart SR-5
Set up to accommodate drivers up to 6’3″ / 250 lbs. 50mm Sodi medium axle, Douglas 130mm / 180mm wheels, Bridgestone YLC 4.5 / 6.0 tires, CRG M10 D17 stub axles, Burris engine mount, #35 RLV Gold / Gold chain. Engine rebuilt and blueprinted Hyper Racing Engines, including: New block & cover, new crank, new rod, new piston kit, and new valves. Three track days on the entire package since assembled including engine.
Sodi Kart ST-32
Zero run time on complete chassis rebuild. Tillett T8 Size XL seat, 50mm Sodi medium axle, new KG Buru bodywork, new Douglas 130mm / 180mm wheels, Maxxis SLR 4.5 / 6.0 tires, new CRG M10 D17 stub axles, Burris engine mount,new #35 RLV Gold / Gold chain. Engine is four races from fresh complete overhaul by Hyper Racing Engines, including: New crank, new rod, new piston kit, and new valves.
Tony Kart Psylo
Zero run time on complete chassis rebuild. Size Medium seat, 40mm OTK medium axle, magnesium 130mm / 180mm wheels, MG HZ “Red” 4.5 / 6.0 tires, Burris engine mount, new #35 RLV Gold / Gold chain, wired electric start with new battery. Strong blueprinted Hyper engine that has never been raced.
