Home Forums General Karting Discussion Auto chain lubrication
This topic contains 9 replies, has 9 voices, and was last updated by  Jeff Salak 5 years, 7 months ago.
  • #5552
    David
    Are there any products out there that will self lubricate chains that are small and practical enough to be used?
    Hypothetically something that had a mechanism to only release lubrication when movement is detected.
    Perhaps a pendulum pump?
    Something that has fine precision adjustment to tune optimal flow rates to the application and specific need?
  • #5589
    I would prefer karts never have them. As soon as one fails on track you have a guy driving around oiling down the racing line not even realizing he’s doing it.
    Spray the chain after every time you pull off track and you’ll never have a problem. If you’re doing robo-pong 200 then maybe consider an oiler, other then that, it runs ~10minutes at a time. Its really not worth it.
  • #5593
    Dan Haynes
    Not sure but I don’t think they are permitted in most series.
  • #5681
    Anonymous
    We used to use them at Purdue Grand Prix. Just a drip bottle mounted above the chain. Turn it on when you fire it up and turn it off when yo ucome off (or it makes a heck of a mess all over the stand and floor).
    I think Dan is right, most series/organizations/tracks dont allow it. Check your local listings.
    -Derek
  • #5683
    Greg Lindahl
    Here, but I don’t suggest it for anything but roadracing and then only carefully so as to not oil down the track and pits.
    <span style=”font-family: ‘Tahoma’,’sans-serif’; font-size: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;”><span style=”color: #000000;”>http://www.scottoiler.com/us/Kits.html?gclid=CITC79713LgCFSFyQgodbngAPg</span></span>
  • #5724
    Jeff Salak
    You dont need an oiler road racing. I run Tag and an o-ring chain.
    Like Paul said, when you pull off track when chain is still warm. Best time to lube.
  • #5742
    Broque Ward
    belt drive is the cure for that.. has anyone ever  built a belt drive?
  • #5743
    William Martin
    It’s common in road racing, not in sprints though. Sprint kart tracks are kind of tough on a tooth belt drive. I tried it years ago, but it kept getting tire rubber stuck in the pulley teeth, then it rips the teeth off the belt…shame it didn’t work better, kart was always clean, no chain lube mess.
  • #5778
    If it’s not broke, don’t fix it. Get a proper chain lube and it should still have plenty of lubrication when you come in after the session.
  • #5844
    Jeff Salak
    No one hardly runs belts even in RR anymore. Less than 5% use belts.
    Broque they have had belt drive systems for years now.
