Home Forums Shifter Karts Anyone use a Swedetech GFS Fuel System ?
This topic contains 5 replies, has 4 voices, and was last updated by  Valentin Yakimenko 5 years, 11 months ago.
  • #8177
    Michael
    How does this work ? I cant believe 400 dollars for a system like that. Could I make one ? Also for those who use this system does it really do all Swedetech say it will do ?
    http://www.fastech-racing.com/swedetech-speed-concepts-gfs-fuel-system.html
  • #8179
    marc-andre hubert
    I don’t have it so can’t say, but im running regular carb with floats properly adjusted and I have no issues with any bogging, overfilling etc clean all the way thru the rpm, not sure its worth it, but im sure it helps but for that money …
  • #8184
    Valentin Yakimenko
    I made my own out of fuel filter with replaceable element. Took it out. Drilled few holes installed Y connector on supply hose and installed a smaller return hose. Worked grat!  AND UNDER 20$.
  • #8208
    Michael
    Valentin- Did you notice an improvement on the bottom end ? Thats what I really want out of this system.
  • #8249
    andy graham
    dellorto fuel pump….check out Musgrave’s site
  • #8251
    Valentin Yakimenko
    Depends on what carb u running. I had this setup on my spare cart with pwk on it. It was great on bottom and top. But as u know pwm is a top end carb. This setup will not change performance of carb. I now have pump around bc I got it cheap, but performance hasnt changed either. If u dont have pump around u just beyter if going with filter setup. I run short sprimt tracks never had problems with fuel slinging in a bowl…and never ran out on long streights.
