Home Forums Classifieds Classifieds – Misc. 360 Plus Device
    • #106923
      Frank Smith
      360 Plus Device for karting. In like new condition. Used for 4 autocrosses. $140. Pick up in Vienna VA or pay shipping.
      Team Valhalla 360 Plus Kart Neck Support
      FRONTAL PROTECTION
      The 360 Plus uses firm foam padding under the driver’s chin. Other devices use rigid plastic which makes them less comfortable and potentially dangerous to the throat area in the event of a frontal impact. The foam is also much denser than the foam in a simple neck collar, which makes it more resistant to frontal hyper-flexion.
      REAR PROTECTION
      The vertical braces of the core piece, located behind the driver’s helmet, help control rear hyper-flexion in the event of a collision with hay bales or other “soft” barriers. The upper vertical brace limits rearward helmet movement by transferring the energy to the lower vertical brace positioned against the driver’s back.
      Side and Vertical Protection
      Low side bolsters limit extreme lateral motion of the head, yet still allow the driver unrestricted head rotation to look from side to side. The bolsters also reduce compression loads on the spine in rollover situations by transferring the load from the neck to the shoulders and torso.
      Protection Unique to Karting
      The 360 Plus Device is designed to break away, minimizing the potential for injury to the throat in the unlikely event that it becomes hooked on something. The device is retained by adjustable straps around the shoulders. It does not require a driver restraint harness or helmet tethers.
      All foam pieces are fully adjustable laterally and front-to-back to suit each driver’s specific physique. Weighs only 1.5 pounds (0.68 kg).
      • This topic was modified 1 year, 3 months ago by Frank Smith.
