06 Birel M32 chassis/40mm axel/ Large ribtect seat Complete plus the following
Freeline alum rims 2-5″x 210, 2-5″ x 130
Freeline Mag rims 3-5″ x 210
2-17mm wild kat Front hub
2- 17mm front hub MFR Unknown
1-40mmRear hub MFR Unknown
2-40mm Freeline Med Hub
2-40mm Freeline long hub
1-40mm long Hub MFR unknown
1-Freeline 40mm x 2.45 x 1040 F axel
1- Freeline 40mm x 3 x 1040 M axel
1- 40mm x 1040 axel MFR Unknown
1-Set 40mm Axel stiffeners
1-Set Bridgestone YJP Rains–60/110-5 and 45/100-5
1-40mm Break rotor and Hub
2-40mm Freeline Sprocket hubs
2-40mm freeline Break rotor Hubs
1 Set Ikponline Break Pads NIB
6-Break pad shims thick
1- AMC 10mm Break Bleeder NIB
1- KG Break rotor Air scoop
1-Freeline steering wheel
1-Freeline Front Chassis stiffener bar
1- Freeline Gas Tank
3-Freeline Gas catch bottles
1-Freeline Break Assembly Complete
Freeline Unpadded large seat
freeline Padded large seat
Bucket of MISC parts and screws
Extra Seat struts
Woltjer Leopard Motor I think this is the serial # t 2623 p 2534–Bore 54.25
Odenthal Motor Mount with extra chassis clamps
Odenthal Pipe Mount
Prospeed Pipe Mount
Drive Gears–2/10T NIB, 2/11T NIB, 2/10T, 1/12T, 1/16T
3–NGK BR9ES, 3–NGK BR10ES
complete motor with the following extra parts
1-Clutch Drum–NIB
1-Clutch Drum Assem for Belt drive
2-Starters
1 Starter rebuild kit
Clutch tools
Flex Tube
Extra Radiator Hose NIB
Sprockets and Parts–
NIB–2@86,2@84,2@82,2@80,1@78,2@76,2@74,2@72,2@70
Used–2@70,1@72,1@74,1@76,1@78,1@80,1@79,1@82,1@89,1@92
1-RK ORING CHAIN NIB 219-112L
2-219 Chain breakers
1-219 O-ring Chain Breaker
Pfeifer Belt drive driven Sprockets 1@77,79,81
Pfeifer Drive Sprockets 1@14,16,18
1-Gates GT-2 840-8mgt Belt
1-Streeter Kart stand
Pics at: https://www.flickr.com/photos/128093020@N07/
I was looking to get $3000.00 for all of it. I live near Buffalo and Frequently travel to Detroit so I might be able to deliver it.Otherwise the shipping is on you. Please email me at Justinsfather2@gmail.com with any questions.
thanks for looking Geoff
