Home Forums Tech Talk water leaking at head bolts Reply To: water leaking at head bolts
#16165
Lawrence Doty
Should be an easy fix.
There are 6 o-rings. 1 each for the 4 head bolts and 2 more for the head. There is also a shim under the small head o-ring.
Drain the water, pull the head off, remove the old O-rings and check to insure you have the shim. Then just install the new O-rings, bolt on the head and refill with water.
You should be good-to-go.
I had the inner head o-ring go out on mine (turned the motor into a waterpump…). after replacing all the O-rings, and installing the shim that was missing, the motor ran great at the last race.
