Home Forums Tech Talk Top Kart Master Cylinder Reply To: Top Kart Master Cylinder
#15665
Dan Breuer
Thanks for the reply John, but it is a new kart and the reservoir does not have any fluid in it. When I looked at another kart, same thing (the ‘reservoir cover’ has two screws to hold it down). The only difference was that on the other gentlemens kart it does have a rubber seal while mine did not (still no fluid in the reservoir). I did get the brakes to bleed out fine (through the allen headed port), just thought it would be easier if it actually had the reservoir working.
Dan
