Home Forums Tech Talk TM K9B running issue? Reply To: TM K9B running issue?
#9425
andrew
Steen Carstensen wrote:
Only replace it if it is faulty. Take it out and have a good look at the needle under a magnifying glass, look for a ring around the rubber seal area or any other irregularity, also check the seat of cause. Make sure the small fibre washer is in place under the seat when you screw it back into the carb body.
thnx much ill give er a look and hope for the best :-)
