Home Forums Tech Talk TM K9B running issue? Reply To: TM K9B running issue?
#9397
Steen Carstensen
I have a question for you, did you clean the carburetor with carb cleaner without removing the needle valve, if you did, you ruined the seal on the tip of the needle and that would cause you having gas in the air box. Check that first and get back to us.
