Home Forums Chassis & Handling Tire Stagger for chassis tuning Reply To: Tire Stagger for chassis tuning
#9792
Bob Baldwin
Blocked
Eric / TJ : Well put I understand what you are saying about evenly matched circumfrence on the rear . Honestly the only time we ever used Kart scales was when the Kart was brand new we went to  OGP hired a tuner for the day did the seat placement and LEARNED some important lessons on Kart Geometry . Pretty much proceeded to try to learn the rest as we went along . other than Tech I don’t recall ever moving the seat again based on what the scales were saying . Probably a mistake on our part . did a lot on rear wheel base and front end Geometry .based on notes but that was about it .
Not sure WHY but I recall making the above changes and the LAST thing we would decide to do on the check list and notes was WHERE to set the Air Pressures at .
TJ: you are also correct about trying to “INDUCE ” a stagger if for NO other reason than SAFETY Purposes .
