Home Forums Chassis & Handling Tire Stagger for chassis tuning Reply To: Tire Stagger for chassis tuning
#9693
You want your rear tires to be the same size. I wouldn’t add air either to induce stagger because like I said, tire pressure is a pretty important tuning tool.
So to answer your questions:
1. Yes, you want equal rear tire circumferences.
2. I’m sure it has a negligible effect since you’re changing the rake of the one side. But you won’t feel the difference. It isn’t really quantifiable.
Bottom line for me is, I don’t want stagger in the rear tires, but if there is some, I put the bigger tire on the outside and don’t adjust tire pressure to fix stagger.
