Home Forums Tech Talk Stripping Paint from Frame Reply To: Stripping Paint from Frame
#14289
Larry Andrews
If you want to see the original metal surfaces/ weld HAZ then you probably want to avoid media blasting and also avoid using anything besides white scotchbrite to loosen the coating.  (yes, this will be frustrating)  Also might be a good idea to throw down some good 2-part clearcoat once you get the frame cleaned off so the steel doesn’t rust too quickly.
-la  (metal finishing guy way back when…)
