Home Forums Tech Talk Smoking Brake Rotor Reply To: Smoking Brake Rotor
#8443
Jaime Cardenas
Thanks for the reply Tony. I checked and the rotor doesn’t rub the brake pads unless I press the pedal. However, on side of the pads is closer to the rotor than the other. Also, on that same side the pad is worn at a bit of an angle. What do you think? Am I dragging the brake pedal while driving?
Jaime
