The part you are referring to is called the cassette. What I usually do with the adjustable ones is take them in my hand with the bearing and snug them. You basically want all the play out, but you should be able to rotate the bearing about the cassette freely, but snug. Too tight and the kart will hop through the corner loading and unloading with a jerking motion…
BTW I would either replace both outside cassettes with new ones, or just replace the one and put it in the middle position….
CR
