Home Forums TaG New starting problem Leopard Reply To: New starting problem Leopard
#8723
Marty Troup
fuel is fine
I rechecked and cleaned the grounding all was fine..
same as before it seemes to start on first try but if you stop it or let it die it will not start even when it turns over fine as if it has no spark then on the next try it will pop through the exhaust or it will seem to try to start for a split second..
Waiting for a external starter..
I see where some are switching to a key start that I do not know about
I have the last couple of leopards around here and there is no support near me. just the Rotax crowd…
