Home Forums Chassis & Handling Lifting inside front tire Reply To: Lifting inside front tire
#14569
The only time I really see front tire lift is in shifters due to being too harsh on the throttle and powersliding the kart.
What condition are your tires in as well?
It sounds a bit like you don’t have enough front OR rear grip. I’d advise continuing to add front grip but the kart already sounds unstable in high-speed corners if you have to lift.
Could it be driving or tire related? Can you eliminate it through driving differently but still maintain your lap times?
