Home › Forums › Shifter Karts › KZ Carb Setup › Reply To: KZ Carb Setup
Martin,
Remember the setup you used for an example is pretty close to the same as far as main jetting is concerned. One needle has 1.50mm tip the other a 1.80. but the different main jetting compensates for difference in needle tips.
