Home Forums Shifter Karts KZ Carb is always overflowing Reply To: KZ Carb is always overflowing
#7424
1) Are the vents routed up over the carb?
2) Do you have a return line to the tank?
3) Is the tank vented?
4) Can you post pictures of your current setup?
5) Why did you replace the round pump with the square one?
Sounds like you don’t have a return to the tank…
