Home Forums TaG Rotax Max Jet-Tech Max Jettign Software Question Reply To: Jet-Tech Max Jettign Software Question
#16707
When you tried a new carb did you use your slide cap and spring? I ask because if the spring on the slide is broken or collapsed it may work when you check it without the engine running but when the engine is running and under load the vacum being pulled through the carb can hold it open. Any bind in the cable or anyplace will do the same thing.
