Home Forums TaG Rotax Max Jet-Tech Max Jettign Software Question Reply To: Jet-Tech Max Jettign Software Question
#16678
John Savage
It’s not the carb if it was still there with another carb, so as you say check the reeds which is a simple visual inspection and also check the fuel pump and its pipework just in case you are leaning out at the end of the straight.
If you do decide on setup as well then the best option is to upgrade to Jet-Tech Pro as you then get additional features that you would not get if you used Jet-Tech Max and Jet-Tech Kart Setup.
Jetting and Kart Set-up Software
http://www.rotaxjetting.com
