Home Forums Tech Talk IKP Brake Pads… Reply To: IKP Brake Pads…
#4076
Doug Ring
Been a couple of years since I ran the Birel, but shimming is not at all unusual to close the gap. Birel dealers will have them, or you can make some yourself out of aluminum sheet. You may need to trim the retaining screw lengths, if the pads don’t have clearance holes bored through the friction material. IKP’s may be harder, hence less material on the pad?
