Home Forums Shifter Karts Honda CR125 intake manifold and the Mikuni carb Reply To: Honda CR125 intake manifold and the Mikuni carb
#4904
Robert Horvath
On the Mikuni carb setup:
I posted this to see if there was much interest in this project and I see that there is…..So I’ll work up a price for the setup.
Would you karters get your own carbs off ebay like this one ? :
http://www.ebay.com/itm/Mikuni-Super-SBN-38-mm-38mm-Carburetor-Carb-Brand-New-/190459013132
Or would you like the Mikuni carb, air box inlet adapter, primer system, gasket, nuts & bolts, throttle cable bracket , custom intake manifold and V force 3 reed box as a complete system ?
Probably not cheap when all added up ?
The intake manifold is about 1/2 inch thick someone asked.
The Carb is a generic replacement carb for my 1995 Polaris triple carb 750 cc watercraft (JetSki). see photo down below :
3 carb JetSki setup
3 carb JetSki setup
Each carb feeds each 250 cc cylinder.
The Jetski has such tremendous throttle response I thought I give it a try on my Honda shifter….It works well so far and I’ll keep you posted after much more track testing of the setup.
I do see now after track testing that I have to set the popoff pressure much lower.
Ocono Bob
Thank You
Robert Horvath
W352N6446 Road J
Oconomowoc Wi 53066 U.S.A.
rhorvath4@wi.rr.com
