Home Forums Shifter Karts Help!!!! Reply To: Help!!!!
#9967
Troy V Smith
First thing that I would swap would be the coil – I have found that no spark is usually a simple, yet overlooked issue.  Sounds like your CDI is a 99, where his may be an earlier model.  Last thing I would be doing though, is shorting out two wires in which I didn’t know the purpose – good chance of ruining a good CDI.  Wires are color coded for a reason.  The two wires which are not connected, may very likely be to a kill switch, in which case would cause you to have no spark when connected together anyway.  Try a coil swap and find out what the wires are before shorting them.  jmo
