Home Forums Shifter Karts HELP! Kart damaged need advice Reply To: HELP! Kart damaged need advice
#10670
Larry Andrews
Most body shops with a frame jig can straighten the frame – the real question regards the amount of damage that has to be done bending the metal back to get the frame straight again.  The metal can only bend so far before it weakens significantly and the front wheel isn’t someplace you want to risk having a sudden stress fracture at.
