Yah, anything is fixable, that frame isn’t fixable…. The main front tube is not bent, it’s kinked, which means it has to be replaced, along with the front porch, and at least the right side bar. It’s a bread box chassis, so it’s pretty old at this point.
And even if you did find somebody to spend the time to repair it, the chassis would never handle the same, and I’m sure it wouldn’t be cheap….
I’m sure you have some money into it, sorry to say, your best bet is to write it off…..
One thing you could do is look for a Road Rebel with rear brakes only, the chassis are usually a lot cheaper, and swap your stuff over….
CR
