Home Forums Chassis & Handling HELP!!! bent CRG frame, need advice. Reply To: HELP!!! bent CRG frame, need advice.
#10671
Jeff Fitzgerald
Good morning all, thanks so much for the comments and help. Here are the pictures of the frame. Looks like it took a direct hit in the front member causing the right front wheel to move backwards. This is not a one piece frame it is almost like it has a front subframe that bolts into 2 tubes.
Let me know what you think after looking at the pics. Follow this link.
https://jefffitz.shutterfly.com/pictures#n_5
Thanks!
Jeff
