Home Forums Shifter Karts Help!!!! Reply To: Help!!!!
#9972
Clark Gaynor Sr.
Two small wires run to the coil.  One is a ground, the other a female slip on connector.  Check both, but especially the female.   The wire breaks or the connector gets corroded.  At some point, that like wire will bite you in the butt.  Ask me how I know that!!??
Good luck.
Clark Sr.
