Home Forums TaG Rotax Max Castror Oil OK in a Rotax? Reply To: Castror Oil OK in a Rotax?
#8795
Steen Carstensen
If you run Rotax series you have to run their oil, if not you can run whatever you have.
If your engine is sealed, I would not run castor as you can not get in there and clean the ring and piston, just buy some Motul or XPS and you are good to go.
