Home Forums Autocross / Solo 2 Carb issue Reply To: Carb issue
#13778
Christian Hubbell
Sounds to me like your return pump can’t keep up or is pumping the wrong way.  Did you rebuild it with new diaphragms and seals?  Can you swap the two?
Pumps should be higher than the pulse line if possible so any oil can drain back to tank but honestly I’ve seen all scenarios work.  High fuel levels can cause issues too.
