Home Forums Shifter Karts Breaking front motor mount bolt Reply To: Breaking front motor mount bolt
#10061
Jon Romenesko
Woah..
I can’t believe that someone else is having the same problem I am!  Its driving me insane. I have an odenthal mount (CR125), but i’ve snapped the front mount bolt several times this year.  The case is a bit worn away for whatever reason, and there’s a gap between it and the mount, but that can easily be taken up with a washer.  Even still, i’m breaking bolts.  I’ve even tried grade 8 bolts with no luck, they all break off clean at the outside of the mount.
Gary, i’ll try your suggestions…(or maybe a new mount is in order).
GP10/CR125
http://theslipangle.com/
