Home Forums Chassis & Handling Seat Mounting Reply To: Seat Mounting
#44288
Michael Monaghan
Mine a little over 8.5″, but you may also need to move it further forward if you are adding any weight to the back of the seat.  If it has a flat spot on the bottom of the seat, make it parallel with the frame rails. This should give you a good angle to start with. What model and year may also have an effect on where the seat is placed. Mine is a 2008 CRG KT11
