Home Forums 2-Cycle Racing Disoonnecting connecting rod from the piston (or vice versa) Reply To: Disoonnecting connecting rod from the piston (or vice versa)
#40359
Len,
With a small needle nose pliers, grab the ring, twist and pull the clip out. To remove the pin without damaging the rod, you might need a puller similar to the one by LAD Specialities, http://www.ladspecialties.com/zoom/100-00034.html.
