Home Forums Tech Talk CR125 strange engine behavior Reply To: CR125 strange engine behavior
#35679
Sanford Mitz
As long as you are checking things, pull the throttle cable all the way out of the sheath and make sure it is not unraveling somewhere. Very lightly coat it with anti-seize compound and put it back in. If you have a right angle in to the carb be sure and check that area.
