Italian Motors - LB
Russell Karting - SS
KG Plastics - FB
Kart, wheel identification and axle sizes
philip richmond
PostPosted: Sun Aug 15, 2010 6:19 pm    Post subject: Kart, wheel identification and axle sizes Reply with quote
Anyone know the best way to identify a kart? I purchased a kid kart ~6 months ago that is supposed to be 7-10 yrs. old. The only identifier I have seen is the Margay steering knuckles.
Same questions for the wheels. We bent the outer rim of 1 wheel. Do I need to purchase a complete rim or look for a used section.
Over the weekend we bent the axle for the 1st time. It is 31.73mm and ~38" long. should I be looking for a 32mm or the 1.25"? Will any 38" x 1.25" axle work or do I need the manufacturer part? I have seen steel and aluminum. Is aluminum worth the effort and couple #s weight savings? The heaviest driver is 140#. Is a used worth the cost savings?
Rich
Rich Eisgruber
PostPosted: Mon Aug 16, 2010 5:46 am    Post subject: Reply with quote
If it is a split rim you could buy the 1/2 rim and replace it. The axle is more than likely a 1.25, I'd try to buy one that is the same thickness as the one you bent
Rich Eisgruber
www.sirakarting.org
Don't blame me, I'm not in charge
DB time: 1.031709 (78.01%), total time:1.322532, queries:38
