KartSport North America - LB
Streeter - SS
SCCA Enterprises - FB
cr 250 cranks
Goto page 1, 2  Next
shaun everard
PostPosted: Wed Aug 11, 2010 9:43 am    Post subject: cr 250 cranks Reply with quote
Will a 2005 crank fit into a 2001 cr????
Ian Harrison
PostPosted: Wed Aug 11, 2010 12:04 pm    Post subject: Reply with quote
Hi Shaun
This is the second time today that this question has arisen!!
The crankshaft will physically fit into the cases. The problem is that the big end eye comes very, very, very close to the cases so in the event of a main bearing or big-end failure you can more or less guarantee that you will split the cases.
You could of course "trench" the cases to provide a bit more clearance, but this will make the sealing flange thinner and more prone to damage from a gentler knock.
My advice is not to do it and just rebuild the crank with a new rod kit after 1 year and replace your standard 2001 crankshaft with new every couple of years.
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
shaun everard
PostPosted: Wed Aug 11, 2010 2:10 pm    Post subject: cr cranks Reply with quote
I'm guessing you were asked this by Andy Dean he asked if I new any one who would no I said yes you Ian the cr 250 God.... [/u]
james jackson
PostPosted: Wed Aug 11, 2010 11:54 pm    Post subject: Reply with quote
Do the 05 cr cranks use a larger crank pin than the 92-01? how much bigger is it?
Ian Harrison
PostPosted: Thu Aug 12, 2010 7:00 pm    Post subject: Reply with quote
Hi James
'92 - '01 = 24mm
'02 - '07 = 25mm
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Jeff Pickel
PostPosted: Fri Apr 27, 2012 10:25 pm    Post subject: Reply with quote
This crank will be going into a cylinder reed valve motor after the mods to crank for clearance issues and changing of bf.[/img]
[img][/img]
Ian Harrison
PostPosted: Sun Apr 29, 2012 4:14 pm    Post subject: Reply with quote
Hi Jeff
Don't forget that if you skim the periphary, that the rod big-end eye will still protrude and describe the same outer profile as it rotates.
You may have to machine some off the outer of the rod big-end eye or the case, I have found the rod eye taps in one or 2 places, but not everytime. you may also want to do this to increase clearance anyway. The O/E rod is plenty strong enough. Don't know about some of the Taiwanese offering like Mitaka or Hot Rods.
Install the crank in the side cases one at a time and fit the cylinder and piston, so you can see what's going on.
Rotate and check for fouling or very close proximity.
Apologies if this advice is basic to you, but it may help others.
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Christian Garcia
PostPosted: Mon Apr 30, 2012 3:28 pm    Post subject: Reply with quote
What about putting the 05 crank in the 02-04 motors and getting rid of the tin covers? Is this a better option?
Christian Garcia
PostPosted: Mon Apr 30, 2012 3:37 pm    Post subject: Reply with quote
Ian Harrison
PostPosted: Mon Apr 30, 2012 11:26 pm    Post subject: Reply with quote
Hi Christian
Yes it is, and we do it all the time in our race motors.
It's just a straight swap, no machining and no issues.
We have found the standard balance factor of the '05 crank fine for Superkkart racing where you are running between say 9,000 and 11,500 rpm.
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Jeff Pickel
PostPosted: Mon May 14, 2012 1:14 am    Post subject: Reply with quote
here is what it looks like under the stuffers.
here is the crank installed in the cylinder reed case.
here is the crank after the machine work and different balance factor
Ian Harrison
PostPosted: Mon May 14, 2012 12:18 pm    Post subject: Reply with quote
Looking good, Jeff
Be interested to know what balance factor you went for and how it works/feels in practice, once you have it running.
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Jeff Pickel
PostPosted: Sat Feb 09, 2013 9:22 am    Post subject: Reply with quote
22 races later at 11,000 rpm no vib or issues.
Jeff Pickel
PostPosted: Sat Feb 09, 2013 9:23 am    Post subject: Reply with quote
good crank
Ian Harrison
PostPosted: Sat Feb 09, 2013 6:19 pm    Post subject: Reply with quote
Hi Jeff
Great job.
Obviously just by skimming the periphery you decrease the balance factor as you remove more weight from the "bob-weight" side, where the crank flywheels are thicker. However, if you machine the outer of the big end eye you lighten it, which goes to counteract some of the effect of the skimming.
Beyond that I don't see any drilling or insertion of tungsten (Mallory metal) bar.
Just wondered if you actually know the percentage balance factor you are running, where in the rpm range you feel the worst vibration periods through the seat-of-your-pants Shocked and the type of chassis that you use?
Here's 2 examples of variously weighted/balanced cranks for the same engine.
My own inclination (prior to start of testing) is an increase in crankshaft mass and a balance factor of around 75%. I'll post my results when the testing is complete.
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.073213 (40.41%), total time:0.181164, queries:38
