OTK - LB
MG Tires - SS
Franklin / Merlin USA - FB
Oil level with 15deg mount?
Mike Wood
PostPosted: Fri Jul 30, 2010 12:15 pm    Post subject: Oil level with 15deg mount? Reply with quote
Hi,
Got a clone on a BMI 15deg. Is there an easy way to know how much oil to add? I could tilt the kart so engine is level - but not sure if the stock/level amount is actually right for an engine sitting at 15degs!
Mike.
GP8 CRF250R shifter
Top Kart clone (for the dirt oval!)
Bernie Lacotta
PostPosted: Fri Jul 30, 2010 1:32 pm    Post subject: Re: Oil level with 15deg mount? Reply with quote
[quote="Mike Wood"]Hi,
Mike.[/quot
Mike , just put in 16 Oz. Don't use the "dipstick" as a guide.
I breathe ,therefore,I race
ted tucholski
PostPosted: Sun Aug 01, 2010 7:28 am    Post subject: Reply with quote
Mike, I have been experimenting with oil levels with the same application as yours. We went from 16oz to 14oz to 12oz. Haven't blown the motor up yet. With the 15 degree mount the oil gets shoved forward in the case leaving plenty of oil for the crank dipper to splash around with less drag. But again at $125 a pop for the motor I will push at limitations. No guarentees.
DB time: 0.083074000000001 (47.39%), total time:0.175312, queries:38
