charles hunter
Joined: 28 Apr 2007 Posts: 732 Location: United States, California, anaheim
Posted: Sun Apr 11, 2010 3:08 pm Post subject: lo 206 carb |
New to 4 cycle and totally clueless does the idle mixture adjustment have anything to do with acceleration from a dead stop and what are you trying to achieve when you adjust it ?? _________________ swampwater smyth concurs "If you aint first, yer last."
------------------>DRSWAMP RACING INC<----------------- |
Bernie Lacotta
Posted: Sun Apr 11, 2010 5:58 pm Post subject: Re: lo 206 carb |
| charles hunter wrote: | | New to 4 cycle and totally clueless does the idle mixture adjustment have anything to do with acceleration from a dead stop and what are you trying to achieve when you adjust it ?? |
Charles , not wanting to get too deep on the subject , but the idle mixture screw is basically to smooth out the idle. In reality I usually idle the Briggs engines high to a point where the idle mixture is out of the loop. But that's me. The intermediate circuit ( the tapered needle in the throttle slide ) is essentially your "acceleration circuit" since the carb does not have an acceleration pump. A little on the rich side here goes a long way in aiding acceleration. See you on the 24th !!!! Bernie _________________ I breathe ,therefore,I race |
