2D2W - LB
SCCA Enterprises - FB
Tony Kart BS4 brakes: fluid and pad question
Joel Pinpin
PostPosted: Sun Mar 28, 2010 7:44 am    Post subject: Tony Kart BS4 brakes: fluid and pad question Reply with quote
Recently bought a used Racer EV and from looking at the caliper, changing out the brake pads means splitting the caliper apart. There doesn't seem to be any bolts or screws that I can remove to get at the pads. Is this correct? Also, I've read the BS4 system (what I have) uses DOT5. Since I'm not sure what grade brake fluid the previous owner used, would it be ok to add in DOT5? What issues could mixing DOT3/4 and DOT5 fluids cause?
William French
PostPosted: Sun Mar 28, 2010 6:50 pm    Post subject: Tony Kart BS4 Reply with quote
Yes, the only way to change the pads is to split the caliper. I would also say it would be a good idea to drain the brake fluid completly and start with fresh DOT5 fluid. Better to be safe than sorry. Good luck.
ROBERT LALONDE
PostPosted: Tue Mar 30, 2010 1:54 pm    Post subject: Reply with quote
Here is a detail assembly of the bs4 brake caliper.
-Remove the two allen head bolts (Z)
-Remove retainer pin (s)
Se-Hoon Kim
PostPosted: Wed Mar 31, 2010 12:18 pm    Post subject: Reply with quote
I believe it is silicone based DOT5. Be careful not to add regular DOT5 in the system.
andy graham
PostPosted: Tue Dec 11, 2012 6:59 am    Post subject: Reply with quote
bs4 requires DOT 4 brake fluid per OTK spec, for the record
William French
PostPosted: Wed Dec 12, 2012 8:39 am    Post subject: OTK Fluid Reply with quote
Hey Andy,
I'm pretty sure only BS1 and BS2 use DOT 4 fluid. DOT5 is required for BS3-BS7 systems. Maybe double check with those that knows for sure. But my memory tells me this. Just want to make sure you aren't running the wrong fluid in all those karts you are building!
See here:
http://j3competition.com/technical/
Randy Mckee
PostPosted: Wed Dec 12, 2012 8:59 pm    Post subject: Reply with quote
DOT 4... or at least that's what I've been told and have run for 5+ years. Maybe that's why I keep hitting barriers. Evil or Very Mad
After doing some research, I see conflicting answers from OTK and/or J3. Curious.
Randy
Tim Doll
PostPosted: Wed Dec 12, 2012 10:45 pm    Post subject: Reply with quote
Mixing brake fluids (glycol - mainly DOT 3&4, and silicone - usually DOT 5, but there ARE exceptions - check the label) is pretty much a guarantee of brake failure. Assuming you survive Shocked , it alsomeans a complete system flush and rebuilt.
DO NOT TAKE A CHANCE!!!!! There is an easy check to see what brake fluid you have. Take a small amount (a teaspoon is plenty) - add a couple drops of water. If the water mixes right in, it's Glycol based fluid - pretty much any DOT 3 or 4 fluid you find will be fine. If the water and brake fluid stay separate (think oil and water), it's Silicone - you need Silcone based DOT 5.
Tim
Standard disclaimer - I'm FREE - No longer affiliated with any organization, I can say whatever I darn well please!.
Everett, Washington
DB time: 0.142776 (43.07%), total time:0.331513, queries:38
