Chris Hinrichs
Posted: Thu Sep 06, 2001 11:47 am Post subject: Airbox Problems |
my airbox is blowing air out of it and not sucking air in durning the next 2 heats i ran my highest rpms and fastest lap i have ever ran what does this mean..
thanks a lot  |
Jimmy Moore
Posted: Fri Sep 07, 2001 4:05 am Post subject: Airbox Problems |
| Sounds like you broke the skirt on the piston. |
Jean Stafford
Joined: 19 Jul 2001 Posts: 324 Location: United States, Ohio, Dayton
Posted: Fri Sep 07, 2001 8:45 am Post subject: Airbox Problems |
I think Jimmy is onto something here Chris.
It does sound like you broke a portion of the skirt off the piston on the intake side. This will allow for the better high end performance, due to a change in the port timing for the intake cycle.
As there are limits to the intake duration in both organizations, you should have a competient engine buider check it out and replace the piston if necessary. In addition, the broken portion will allow for more piston "slap" and a much shorter rod life, so check it out soon. |
