Ocala Gran Prix - LB
MRP - SS
Franklin / Merlin USA - FB
Wiring a WF
Frank Hein
PostPosted: Mon Mar 15, 2010 7:42 am    Post subject: Wiring a WF Reply with quote
Going to mount the new WF to a new Arrow 4S this week. All the parts we need are in brown trucks somewhere in the US except for the electrical stuff.
Have a new B&S switch 557028 coming and we'll use a Rotax Yuasa battery and box. The wiring diagram on p. 12 of the WF manual is nice but doesn't give the details.
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=29jnvIX.-FzXFix2
Where's a clever place for the switch to be mounted and do we need to fab a mount? What gauge wires and what fuse to put where?
I've been through 4cycle.com and as usual there is info but isn't gathered into a concise answer. One suggestion is to use a rider mower wiring harness.
There wasn't any info on ekn so maybe some authority could get it down here in the B&S forum. A few clear photos would be the icing on the cake. Thanks
Frank
Arrow AX9-4S / Briggs World Formula
PostPosted: Mon Mar 15, 2010 11:37 am    Post subject: Reply with quote
It's pretty straight forward, hot lead from the battery goes to the threaded lug on the solenoid, ground the battery on your motor mount or engine case. Starter button is a momentary (normally open), one side goes to the same lug as the battery, the other side goes to the spade terminal on the solenoid.
Use good quality stranded 8 or 10 gauge wire for the battery cables, 14 gauge is plenty for the switch. You can mount the switch anywhere you like, you could even mount one next to the kill button on your motor plate.
If you're heavy like me and your club doesn't require it you might just want to take the starter off and pull start the thing. They start pretty easy, and unlike 2 strokes they rarely stall when you spin out. It's quite a bit of weight you can easily remove without any negative effect.
Sorry, no pictures but let me know if you have any other questions.
Cheers,
Heartbeat Power, LLC.
Bernie Lacotta
PostPosted: Mon Mar 15, 2010 5:07 pm    Post subject: Re: Wiring a WF Reply with quote
If you have an Arrorw 4S there is a nice little "dash" in the Number Panel. Right where the fuel overflow catch can goes there is already a hole drilled for the start switch. Atleast mine was like that. The Arrow has some great details on it !
I breathe ,therefore,I race
michael schorn
PostPosted: Tue Mar 16, 2010 7:52 am    Post subject: Reply with quote
Man I typed out a whole response and looks like it didn't post. Must clicked preview instead of submit.
Anyway John explained it pretty well.
The battery you are wanting to use may not last that long as it is I believe a 9.0 ampere hour battery.
The Briggs starters use a bit more juice than the Rotax starters so you may want to consider a higher amp rating battery if you want to use the starter. Or you will need to charge it on a regular basis.
The bueaty of the WF is if the battery is dead, just pull start.
Up in the Northwest Most everyone does not run the battery or starter.
The beauty of it is if these things almost always start on the first pull or two. Even my ten year old can start me.
A good portion of the drivers don't need extra ballast anyway and for those that do like to put weight in different places.
There a couple of drivers that use the electric start and are happy with it.
OK everyone It's my opinion only, no one elses, and does not reflect any organization or office that I belong to or hold. Thank you for your support.
Portland Karting Association
Host 2013 IKF 4 Cycle Sprint
& Road Race Grand Nationals
Frank Hein
PostPosted: Tue Mar 16, 2010 8:21 am    Post subject: Wiring a WF Reply with quote
Doh! Hate it when that happens.
Thanks Mike, Bernie and John for the responses.
I've just assumed that I'd want the electric start feature but maybe not. At the very least it would save me the price of a battery.
I need to find out what our local rules are or will be. As far as I know I'm the one and only WF committed to running in New England. I think I'm close on weight at 175 lbs. but I don't even know what minimum weight will be. I think Mike and George http://www.granitestatekartchampionship.com are starting with WKA rules and adjusting as necessary.
I've been conserving my hobby budget and haven't paid for WKA membership or even $25 for the rules book. Anyone have an idea about how I could access the relevant WKA - WF rules?
Frank
Todd P Weaver
PostPosted: Tue Mar 16, 2010 9:38 am    Post subject: Reply with quote
Frank,
I took the starter off to save weight. I'm 200#s.
regarding the ease of pull starting, Usually it will take a little choke and a couple pulls the first time you start it that day. After the first start of the day, I've found it to be no choke and one pull starting for the rest of the day.
When I'm on the grid, I start it about a minute before I go out to let it warm up.
Todd
Margay 4.7
Turner World Formula SS
#51 Team Axles of Evil
PostPosted: Tue Mar 16, 2010 12:00 pm    Post subject: Re: Wiring a WF Reply with quote
If you're the first one you get to make the rules Laughing
Seriously though the closer you can stick to national rules the better. I hate it when someone needs a motor built that is "just like WKA, except for...."
I think the major orgs allow you to take the starter off if you want, it's no advantage other than less weight. Just take it out of the box and run it, WF is a great package as is.
Cheers,
DB time: 0.290859 (69.72%), total time:0.417159, queries:38
