Marty Redmon
Posted: Fri Mar 12, 2010 3:25 pm Post subject: Briggs Intek 206 speed secrets |
We just moved to an Intek class, all stock no motor modifications, just looking for a few speed secrets to get us in the hunt. i think max rpm's we are at is 5600.
I bought the motor and found exhaust valve slightly leaking, so i lapped the valves, seems to be a little better and pulls a little over 30 psi compression.
Help please. |
Joined: 04 Dec 2004 Posts: 1994 Location: United States, Michigan, Williamsburg
Posted: Sat Mar 13, 2010 7:43 am Post subject: |
Tires. _________________ John Matthews
Heartbeat Power, LLC. |
Rich Eisgruber
Posted: Sat Mar 13, 2010 12:34 pm Post subject: |
| John Matthews wrote: | | Tires. |
And chassis setup. Smooth is fast _________________ Rich Eisgruber
www.sirakarting.org
Don't blame me, I'm not in charge |
Chad Stapleton
Posted: Sat Mar 13, 2010 4:04 pm Post subject: Re: Briggs Intek 206 speed secrets |
| Marty Redmon wrote: |
Help please. |
You need a LOT more than 30 psi . ! ( 150+ psi)
How are you checking it ? _________________ Chad
"Those of you who think you know everything are annoying to those of us who do !!" |
Marty Redmon
Posted: Sun Mar 14, 2010 9:08 am Post subject: |
Checked with a compression gauge and pulling the crank rope 3 to 4 times, i will try a leak down this week.
we struggled again last nite but with some local help improved a great deal with just setup and running the correct line. i think we are on the right track and can start searching for some speed with gearing and carburation, and ever so important seat time. |
Chad Stapleton
Posted: Sun Mar 14, 2010 4:30 pm Post subject: |
I suspect you have a motor with a "decompression" easystart feature that lifts the exhaust valve when you pull it over.
Drop the rocker off the exh valve , and try again. _________________ Chad
