Ocala Gran Prix - LB
Brett King Design
Clutch fitting
Chad Stapleton
PostPosted: Tue Jul 24, 2001 1:55 pm    Post subject: Clutch fitting Reply with quote
I have been told by some folk that the Horstman DXL will fit onto the "normal" short crank set up on a PRD RK100, but a kart shop have advised that a longer crank half is used. What is the facts ? Is there a Clutch which will fit onto the "standard" (short) IAME style crankshaft.
Thanks in advance for what is probably a 'no-brainer' question to you all!!
Chad Stapleton
PostPosted: Mon Jul 30, 2001 3:57 pm    Post subject: Clutch fitting Reply with quote
Come on guys, some one out there must know if i can get a clutch to fit the short crank ??
Even a direct mail to Horstman has failed to get a reply ????
Scott Patchin
PostPosted: Tue Jul 31, 2001 7:06 pm    Post subject: Clutch fitting Reply with quote
Gee Chad,
No replies yet? wish I could help you out but I cant, I dont know the answer...........someone out there should know.
Curtis Lamb
PostPosted: Wed Aug 01, 2001 4:40 am    Post subject: Clutch fitting Reply with quote
Maybe you should try to re-post it to the tech hit squad section...?
Rick Crow
PostPosted: Wed Aug 01, 2001 6:06 am    Post subject: Clutch fitting Reply with quote
If you can't find someone on these forums, You might try the 2 stroke forum at www.4cycle.com , many of those guys are into
building and modifying air cooled kart engines and might be able to help.
Rick
Jimmy Moore
PostPosted: Wed Aug 01, 2001 6:16 am    Post subject: Clutch fitting Reply with quote
Chad, call TS racing at 1-800-962-4108 they are the ones that are movin' and a groovin' with the PRD RK100.
Chad Stapleton
PostPosted: Wed Aug 01, 2001 2:05 pm    Post subject: Clutch fitting Reply with quote
Thanks for the suggestions guys,- i will follow them all up- , but this is not just a question about the PRD, really it is general for all 100cc 2-strokes, Yamaha, PCR, ITAL, Parilla etc who all have alternative "long" cranks for use with a clutch. I know they have various taper fittings, but it would sure be good to know for certain if there is a clutch design somewhere that will fit the "standard" short crank nose on any, or even only some of, them ?????????
DB time: 0.273196 (56.44%), total time:0.48406, queries:37
