Bondurant - LB
SCCA Enterprises - FB
Wb3a on Open fuel
Jimmy Moore
PostPosted: Fri Jul 27, 2001 8:21 pm    Post subject: Wb3a on Open fuel Reply with quote
How much methanol can you mix with the gas and still get a stock Wb3a to run right on a Yamaha. Somebody told me 25% but, that sounds like alot.
Sean Cook
PostPosted: Sat Jul 28, 2001 7:11 pm    Post subject: Wb3a on Open fuel Reply with quote
Jimmy,
What would be the point in useing methanol in a stock WB3A carb on a Yamaha? The rules require spec gasoline.
Jimmy Moore
PostPosted: Sun Jul 29, 2001 7:17 am    Post subject: Wb3a on Open fuel Reply with quote
The point is to make it go faster and run cooler with less carbon deposits. We don't have any gas rules at our track.
Dale Floyd
PostPosted: Sun Jul 29, 2001 3:32 pm    Post subject: Wb3a on Open fuel Reply with quote
Jimmy, do you run at Oreville?
Jimmy Moore
PostPosted: Mon Jul 30, 2001 9:38 am    Post subject: Wb3a on Open fuel Reply with quote
What's Oreville? we just run 'um through the woods.
Pete Muller
PostPosted: Tue Jul 31, 2001 6:46 am    Post subject: Wb3a on Open fuel Reply with quote
quote:
Depends on the weather and the exhaust pipe.
25% shouldn't be a problem at all though.
PM
Jimmy Moore
PostPosted: Tue Jul 31, 2001 6:57 pm    Post subject: Wb3a on Open fuel Reply with quote
The exhaust is a 4 hole can and lets say the weather is "standard day" conditions. Where is the gray zone, 50% ? How can you tell you're having a problem? Would a Wb3a handle 50% methanol if you drill some of the holes a little bigger and add a dump tube to the high jet? Is it really worth messing with for less than 50% ? I think the HP boost would only be about 1/4 horse for 25%. What do you think PM, would it be better to go with 4 oz. of nitro?
Jimmy Moore
PostPosted: Tue Jul 31, 2001 7:02 pm    Post subject: Wb3a on Open fuel Reply with quote
The impression I get is that with methanol you have trouble getting enough of it go through the carb to feed the engine but, with nitro the carb feeds the engine just fine but you have a problem running rich enough to keep the enigne cool. Does that sound right?
DB time: 0.10447 (50.27%), total time:0.20782, queries:37
