MIR Racewear - LB
MRP - SS
KG Plastics - FB
Rotax new style clutch
Darren Campbell
PostPosted: Sun Mar 07, 2010 1:23 pm    Post subject: Rotax new style clutch Reply with quote
Just done the conversion to new clutch and gears but what gear oil should i use will any type of gear oil do??
Chad Stapleton
PostPosted: Sun Mar 07, 2010 3:04 pm    Post subject: Reply with quote
Surprised did you get the NEW 2010 clutch or the 2009 version ?
There has been a design revision ! Rolling Eyes Crying or Very sad
Chad
Lewis Cronis
PostPosted: Sun Mar 07, 2010 4:34 pm    Post subject: Reply with quote
What type of oil depends on what revision of crankcase/gear cover you happen to have.
Some said 15W-40, some said SAE30. The manual also said 15W-40 at one time. It was one of the great discrepancies in Rotax.
Depending on your ambient temperatures, choose an oil viscosity appropriately.
Also remember that the old (plastic) gears had a line on the side of the cover which corresponded to about 50cc. There was also a screw which could be removed to check proper fill level.
The new (metal) gears changed things a bit. You now need 100cc and you can no longer use the line nor check screw on the side of the cover.
It doesn't really matter much, since as a matter of normal maintenance, you should be draining the oil and checking it for particles regularly anyways.
DB time: 0.140933 (44.5%), total time:0.316701, queries:38
